HyperCrash
Messages
Messages
Previous topic Next topic Expand/collapse all hidden text
Messages
The directory, $MCRASHDIR/messages/CONFIG  contains the files with all the messages that will be displayed in the message window and in the dialog toolbar.
Two files are located in this directory:
•msg_arrays
•msg_table
It is strongly recommended to not modify these files.
If you need messages in another language, please send an email to: hwsupport@altair.com
Cards:
Keyword{
Arguments 1
Arguments 2
Arguments n
The comment lines start with:
•character  /* and finish with */ (can be written on several lines).
•character  // and finish with the end of the line.
hmtoggle_plus1Example
KERNEL {
 0000  "ERROR: Not possible to open \"%s\""        // comment
 0001  "ERROR: End of file \"%s\""
 0002  "Quoted string not found"
 0039  "Not possible to define USER subtype (%i) for a %s"
 0040  "%s is not a subtype of %s"
 0041  "Not possible to add a %s into an ARRAY of %s type"
* the text in blue may be modified.
Go to
Main Module Environment File Description
