HyperCrash
To modify or delete an Imposed Velocity
1.From the Menu Bar, select Imposed Velocity > Modify.
2.Select imposed velocities using one of the following options:
Button
Behavior
treeSelectUnselectAll-24
select all the imposed velocities.
selectGeneral-24
pick the arrow for the imposed velocity in graphic window to select it. When finished, answer the question in the Dialog menu bar with Yes or Cancel.
selectSpotweldByBox
select imposed velocities by box (use the SHIFT key to use a polygon box).
selectPartGeneral-24
pick parts in the graphic window to select all the imposed velocities applied to those parts. When finished, answer the question in the Dialog menu bar with Yes or Cancel.
selectPartByBox-24
select parts by box (use the SHIFT key to use a polygon box) to select all imposed velocities applied to those parts.
Click the imposed velocity line in the listing window to select it. Several imposed velocities from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys.
3.Select only one imposed velocity and click reviewGeneral-24 for the option to do any of the following:
•Change the imposed velocity name.
•Select or deselect nodes or parts (see Node selection).
•Modify the skew frame (see Reference axis).
•Modify the sensor (see Sensor).
•Modify the properties (see Properties setting).
•Modify the imposed velocity direction (see Direction setting).
4.Click deleteGeneral-24 to delete the selected imposed velocities.
5.Answer the question in the pop-up dialog window with Yes or Cancel.
6.Click Save to save the modified imposed velocity; or
Click Cancel to cancel the imposed velocity modification.
7.Click Close to close the menu.
Go to
Imposed Velocity
