HyperCrash
To create a group
To create a group
To create a group
From the top of the Selections sub-window, select the Added or Removed radio button.
Node or element selection
Several options can be used in order to select nodes:
•Click selectgeneral-24 and pick nodes in the graphic window.
•Click ellipse_icon to add/remove nodes by ellipse selection
•Click selectbyboxadd-24 to add nodes by box selection:
oThe default box is rectangular.
oUse the SHIFT key to define a polygon box.
•Click selectbyboxremove-24 to remove nodes by box selection:
•Click 10_addallnodes to add all nodes in the graphic window.
•Click selectPartGeneral-24 and pick parts in the graphic window.
•Click selectPartByBoxAdd-24 to add parts by box selection:
•Click selectPartByBoxRemove-24 to remove parts by box selection:
•Click treeAddEntity-24 to add the parts selected in the tree.
•Click treeRemoveEntity-24 to remove the parts selected in the tree.
•Enter the node identifier number in the Node by Id window and click Ok.
•Create and/or modify a box definition.
Options
•Inc. conn. nodes
oSwitch on: automatically include the connections nodes (spotwelds, glue, etc.).
oSwitch off: automatically remove the connections nodes (spotwelds, glue, etc.).
•Inc. RB master nodes
oSwitch on: automatically include the master nodes of the rigid bodies which have all slave nodes included in the group.
oSwitch off: automatically remove the master nodes of the rigid bodies which have all slave nodes included in the group.
•No selection change
oSwitch on: retain the same include selection as before the group modification.
oSwitch off: update the same include nodes list.
Note: It is recommended to keep these default options.
Go to
Global: Group Selection
