HyperCrash
To define a box
To define a box
To define a box
In the selection by BOX GROUP sub-window:
1.Select one or several box(es) in the list and click reviewGeneral-24 to view the box(es).
2.Click boxNewGeneral-24 to create a new box.
A Group by Box window appears:
3.Enter the group name in the Group name window.
4.In the Original Position:
•Clickselectgeneral-24 and pick a node in the graphic window.
or
Enter X, Y, and Z coordinates.
•Click Ok to validate the point definition.
5.In the Ending Position:
•Click selectgeneral-24 and pick a node in the graphic window.
or
6.In the Dimensions portion, modify the size of the box:
•Use increaseDecrease to change the size of the box for each direction.
or
Enter the size of the box in the dimensions windows.
•Click Ok to validate the modified box size.
7.Click see_box_10 to update the box display.
8.Click Save to save the box creation; or
Click Cancel to cancel the box creation.
9.Click Close to close the box creation window.
Box modification
1.Select only one box in the list window.
2.In the pop-up menu (right button of the mouse) select the function, Modify.
In the box creation window that appears:
3.Modify the box parameters as defined in the box creation.
4.Click see_box_10 to update the box display.
5.Click Save to save the box creation; or
6.Click Close to close the box creation window.
Box deletion
1.Select a box in the list window (using the SHIFT and CTRL keys).
or
Click treeSelectUnselectAll-24 to select all listed boxes.
2.Click deleteGroupsbyBox_10 to delete the selected boundary conditions.
or
In the pop-up menu (right button of the mouse) select the function, Delete.
3.Answer the question in the Dialog menu bar with Yes or Cancel.
Go to
Global: Group Selection
