HyperCrash
Global: Skew Frame
Global: Skew Frame
Global: Skew Frame
This option will appear in any module where a skew can be set and defined.
Create a skew
In the Reference Axis sub-window, a skew frame can be defined:
1.If the Global toggle is active, the boundary condition will be in the global skew frame.
2.Click Moving Local to define a moving local skew frame:
•In the graphic window, pick three nodes to define the local skew frame.
•Click Save to save the local skew frame, or click Delete to cancel it.
3.Click Fixed Local to define a fixed local skew frame:
•Set a name in the Local Reference Axis name window and click Ok.
•Click databaseImport-24 to select a pre-defined fixed local axis. In the Local Axis file window, select a local axis, click OK to validate, and then in the graphic window, pick one node to view the local axis.
or
Fill in the XY plan definition fields to define the XY plane.
4.Click See.
5.In the graphic window, pick a node to display the local axis.
6.Click Save to save; or
Click Delete to cancel.
Modify a skew
In the Reference Axis sub-window, it is not yet possible to modify a local skew. It is only possible to delete it and recreate a new one.
Delete a skew
In the Reference Axis sub-window of the menu / Modify pages, a skew frame can be defined.
1.Click See.
2.In the graphic window, pick a node to display the local axis.
3.Click Delete to cancel the local skew.
