HyperCrash
Global: Sensor
Global: Sensor
Global: Sensor
This option appears in any module in which a sensor can be set and defined.
Create or Modify a Sensor
In the sensor folder:
1.Click the sensor list menu and select a sensor type.
•If the selected sensor is TIME:
oEnter the time value when the sensor will be activated.
•If the selected sensor is DIST:
oClick vectorCreateBy2Nodes-24 and select the two nodes which will define the distance.
oEnter the time delay for the sensor activation.
oEnter the minimum distance between the two selected nodes to activate the sensor.
oEnter the maximum distance between the two selected nodes to activate the sensor.
The sensor will be activated when the minimum or maximum distance is reached and after the time delay.
2.To save the created sensor, click Save; or to delete the created sensor, click Delete.
