HyperCrash
To modify or delete an Imposed Displacement
From the Menu Bar, select LoadCase > Imposed Displacement > Modify.
Selection
Button
Behavior
treeSelectUnselectAll-24
select all the imposed displacements.
selectGeneral-24
pick the arrow for the imposed displacement in graphic window to select it. When finished, answer the question in the Dialog menu bar with Yes or Cancel
selectSpotweldByBox
select imposed displacements by box (use the SHIFT key to use a polygon box).
selectPartGeneral-24
pick parts in the graphic window to select all the imposed displacements applied to those parts. When finished, answer the question in the Dialog menu bar with Yes or Cancel
selectPartByBox-24
select parts by box (use the SHIFT key to use a polygon box) to select all imposed displacements applied to those parts.
Click on the imposed displacement line in the listing window to select it. Several imposed displacements from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys
Modification
Select only one imposed displacement and click reviewGeneral-24 for the option to do any of the following:
•Change the imposed displacement name.
•Select or deselect nodes or parts (see Node selection).
•Modify the skew frame (see Reference axis).
•Modify the sensor (see Sensor).
•Modify the properties (see Properties setting).
•Modify the imposed displacement direction (see Direction setting).
Deletion
•Click deleteGeneral-24 to delete the selected imposed displacement.
•Answer the question in the pop-up dialog window with Yes or Cancel.
Validation
•Click Save to save the modified imposed displacement.
or
•Click Cancel to cancel the imposed displacement modification.
•Click Close to close the menu.
Go to
