Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
- Set the model unit to millimeters.
Define the following variables.
- fmin = 1.3e9 (The lowest simulation frequency.)
- fmax = 1.5e9 (The highest simulation frequency.)
- h = 70 (The height of the dipole.)
- wireRadius = 0.1 (The radius of the dipole segments.)
Create the dipole.
Create a line.
- Start point: (0, 0, -h/2)
- End point: (0, 0, h/2)
- Label: dipole
- Add a wire port (vertex) to the middle of the line.
- Label the port Port1.
Create a line.
- Set a continuous frequency range from fmin to fmax.
Create a general network using a SPICE circuit.
Rename the label to MatchingNetwork.
Note: The network label must correspond to the internal network name used in Match_circuit.cir.
Matching circuit .SUBCKT MatchingNetwork n1 n2 c1 n1 0 2.43pF l1 n1 n2 41.2nH .ENDS NWN1 .end
Create a voltage source.
- For Port select MatchingNetwork.Port1
In the schematic view, connect Port1 (the dipole) to Port2 of the
network.
