Altair® Monarch® Server
Monarch Server Installation
You need to start NetTcpPortSharing in Windows Services if the application uses TCP (by default).
1.     Click Start, point to Administrative tools, and double-click Services.
2.     Right-click on NetTcpPortSharing, and select Properties.
3.     In the Startup type drop-down list, select Automatic, and click OK.
Next time you start Windows, the service will be started automatically.
It is recommended that you stop Internet Server Services before you begin the installation.
You must be logged on as a local administrator on the machine where you are going to install the Monarch Server system, or the UAC should be turned off during the installation process.
NOTE
If some system files are to be replaced during the installation, you will see a message informing of a Windows restart requirement at the end of the installation.
Open the directory with the installation files, and check whether it contains the license file labeled as “ds.lic.” If not, copy this file from the original Monarch Server installation media to the directory from which you are going to install Monarch Server.
NOTE
If the configuration machine name in the license file is not the same as the machine name of installation, the warning message is displayed: “Config machine name in license does not match current machine name. Config service will not start properly.” You can proceed with the installation.
For the recent versions of Monarch Server, you can proceed with the installation without a license. The licensing can be configured after completing the installation. Details are available here.
Single Server Installation
1.     In the directory with the installation files, double-click MonarchServerv2021x64.msi in case of 64-bit Windows to launch the Monarch Server Setup Wizard.
Click Next.
2.     The End-User License Agreement dialog box appears.
If you agree to the license terms, select the check box below the text, and click Next.
3.     The Custom Setup dialog box appears.
You can select the following components to be installed:
·          Configuration Service manages the system configuration and tracks license agreements. It can serve more than one instance. In most cases, only one instance of Configuration Service should be installed.
·          Agent Service manages services (modules) on a particular server. It should be installed on every server used for MS installation.
·          Repository is a folder containing module packages. A package is a 7-Zip archive containing all assemblies required by a module. In most cases, only one instance of Repository should be installed.
Click Next.
4.     The Destination Folder dialog box appears.
Click Next to install Monarch Server in the default folder, or click Change to select another folder.
5.     The Config properties dialog box appears.
Set the following properties:
·          In the Repository field, specify the path to the folder where the Repository will be located.
Click Next.
6.     The Agent properties dialog box appears.
·          In the Config Address field, specify the address where the Configuration Service will run; ‘localhost’ should be replaced with the FQDN of your server (e.g., net.tcp//myserver.domain).
·          Select the Start after installation check box if you want the Agent Service to start immediately after the installation.
Click Next.
7.     The Service account dialog box appears.
Select the Use “Local System Account” check box if you want to use a local system account.
Otherwise, clear the check box and specify a custom user in the Account name box.
NOTE
In case of a distributed installation, if you specify a custom user in the Account name field, NTLM authentification is applied.
8.     The Export Properties dialog box appears.
Specify the export storage settings:
·          Select the Use local DB option if you want to use a local database as an export storage.
·          Select the Use custom database option if you want to use a custom database as an export storage, and then specify its parameters:
¨        Server name
¨        Authentication credentials: user name and SQL password. If you want to use Windows authentication, select the corresponding check box.
NOTE
Using a custom database means Monarch Server will need to be able to create/destroy work databases dynamically. Contact Altair Support for further information and guidance if required.
Click Next.
9.     The following dialog box appears.
Click Install to begin the installation.
10.   After the installation is complete, the following dialog box appears.
Select the Launch Configurator check box to run the Configurator immediately. Click Finish to exit the Setup Wizard.
Now you can access the following options via the Start menu, under All Programs, Monarch Server, Monarch Server 64-bit:
·          Run Agent Service in console mode
·          Run Configuration Service in console mode
·          Run Configurator
·          Uninstall
Creating Instances
You can create instances using the Configurator tool.
The Configurator will launch immediately after installation if you select the corresponding check box.
NOTE
You can run it manually by selecting the Run Configurator option on the Start menu.
To create an instance
1.     From the drop-down list in the top right corner in the Monarch Server Configurator window, select the domain server name and port where the Configuration Service runs, and click Connect.
NOTE
The default service URI can be net.tcp://localhost. However, the Configuration Service can be launched on any computer. In this case, the URI should contain the domain server name.
2.     Select the Configurator tab, and click the Instances tab.
3.     Under Global Settings, specify the connection string parameters: server name, database name, user, and password. Click Test Connection. You will be prompted to update the database.
NOTE
Select the Integrated Security check box if you want to access SQL Server via Windows Authentication. This option is based on the context of the user running the Configurator  application and NOT the Config Service.
If there is no database with the specified name, a message will appear asking if you want to create a new database.
Note that you need to configure a valid license to make any database operations.
4.     Under Instance License, specify the path to the license file.
5.     Click Apply.
6.     If you want to create several instances, each using its own database, click the Add new Instance button, type the new instance name, and specify the parameters described in Step 2.
NOTE
For additional information about setting instance parameters, click here.
Installation of Web Applications
You need to install the Admin and Client applications for each instance.
1.     Go to the directory with the installation files, and double-click Web.Installer.exe.
2.     In the Monarch Server Web Installer dialog box, type the instance name (or leave the field empty if you plan to install only one instance), and click Install.
NOTE
If you install only one instance, double-click MonarchServerWebv2021x86.msi (or MonarchServerWebv2021x64.msi in case of 64-bit Windows) to launch the Monarch Server Web Setup Wizard.
3.     The Setup Wizard dialog box appears. To proceed, click Next.
4.     The End-User License Agreement dialog box appears.
If you agree to the license terms, select the check box, and click Next.
5.     The Custom Setup dialog box appears.
Select the components to be installed. For single server installation, install all the components. Click Next.
6.     The Web Applications properties dialog box appears.
In the Site field, specify the site name where the Web applications will be installed.
NOTE
Select this site name from those listed in the Internet Information Services (IIS).
Under Virtual Folders, specify the names of the virtual folders for Administrator, Client, and RMS Client.
NOTE
The installer creates virtual folder names using the template DsAdmin%instance_name% and maps them to the corresponding folder at C:\inetpub\wwwroot.
In the Port field, specify the port where the IIS runs.
In the Pool field, specify the name of the application pool to be used by the Web applications.
Click Next.
7.     The Config properties dialog box appears.
In the Admin Config Address field, specify the address where the Configuration Service runs for the Admin application.
In the Client Config Address field, specify the address where the Configuration Service runs for the Client application.
In the RMS Client Config Address field, specify the address where the Configuration Service runs for the RMS Client application.
Click Next.
8.     The following dialog box appears.
Click Install to begin the installation of the chosen applications.
9.     After the installation is complete, the following dialog box appears.
Changing the Account
To change the account
1.     Click Start, select Control Panel, and point to Administrative Tools.
2.     Double-click Services.
3.     Double-click Monarch Server Agent Service.
4.     Select the Log On tab and specify account properties.
5.     Click OK to save the changes and start the service.
Distributed Installation
All installation steps for single server installation are valid for distributed installation with the following remarks:
q  In Step 7, in the Service account dialog box, you specify the logon account for MS services. If you specify a custom user in the Account name field, NTLM authentification is applied.
The following table provides details on the interaction of services in case of distributed installation.
q  You may install Client, Admin, and RMS Client applications together or separately on any server allowed by your license.
·          Install Agent on each server.
·          Configure the list of services that should run on each server.
NOTE
LOAD BALANCING
Every server tries to execute a task locally (with the tasks sorted according to execution time). It then checks the count of threads in the thread pool.
q  If the thread count in the thread pool is the same across all servers, CPU utilization is >95% (check the Configuration Dashboard for the specific server for a given parameter or logs similar to "Server server_name utilization is percentage% processor time").
q  If the thread pool lacks free threads (see logs similar to "Server server_name pump thread pool used used_number of pool_count (percentage%)"), the task being executed is forwarded to another server with low utilization.
To configure the list of services
1.     Select the Run Configurator option from the Start menu.
The Configurator will be launched.
2.     From the drop-down list in the top right corner in the Monarch Server Configurator window, select the domain server name and port where the Configuration Service runs, and click Connect.
3.     Under the Configurator tab, select Servers, and configure the list of services that should run on each server.
NOTE
If you use the Active Directory security provider:
q  Launch the Admin Host using an account that has the permission to receive the Active Directory (AD) users list.
q  Launch the Client Host using an account that has access to the AD.
