The Monarch Data Prep Studio Toolbar and Windows
The Monarch Data Prep Studio interface includes a toolbar that remains visible regardless of the window or page you access.
Hover on a tool to get a brief description. Click on the tool to go to the main help page of that tool.
The Monarch Data Prep Studio windows
Monarch Data Prep Studio has five windows, i.e., Start, Preview, Prepare, Combine, and Export, each of which allow you to carry out a specific action towards completing data integration, preparation, and transformation. These five windows can be accessed directly from the toolbar. The Report Design Window becomes available only when you open or edit a PDF or report document.
When selected, the Combine and Analyze stages allow you to combine data by appending or joining and create summaries, respectively.
Window and tool Descriptions
Window |
Description |
Allows you to:
Allows you to open a file. It also allows you to:
Allows you to:
Allows you transform the columns of your unified table. For instance, you can:
Allows you to:
Allows you to join data from two or more tables, so that you have one unified table to work with. |
Allows you to create, view, modify, and manage summaries |
Allows you to export your workspace to several popular file formats, file systems, and Knowledge Hub. |
Allows you to build a table by selecting fields on a document. The resulting table then becomes available in the Preview Window, so you can load it and then eventually combine with other tables or data sources. This window is only available only when you open a report document. |
Clicking this icon launches a text field into which you can enter a comment or description of the workspace. |
Allows you to save your current workspace. Your workspace includes:
Opens the Data Source Library, which will then allow you to select and use data sources made available to you. |
Presents setting options that allow you to, among others:
