2026
拡張定義、OMLガイド、ブロックライブラリ、および用語集。
OpenMatrix is a mathematical scripting language.
Errors and warning messages are both output in the console (or the Command Window in GUI mode) of Twin Activate.
See the Try/Catch description in the Flow of Control and Looping section.
Twin Activateの新規機能や特徴について紹介します。
Twin Activateの使用を開始する際の基本的な情報。
チュートリアルを活用してTwin Activateを使用してください。
Twin Activateで利用できる機能や特徴について紹介します。
ユーザーズガイドの主要なトピックに関する詳細情報。
Literals are items that are constant throughout the life of the application. Literals include numeric, imaginary, characters, strings, logicals, and Other (NaN/Inf).
Data types are items that are constant throughout the life of the application and are built into the OpenMatrix language.
Strings are arrays of characters.
OML language scripts manipulate data through variables. Variables are referred to by their name (alphanumeric) and can be created (assigned) and deleted as described in this section.
Indexing is used to retrieve one or more specific values out of a collection.
Operators are used to combine operands.
Each operator in this section is explained with the operations of scalars, vectors, and matrices that are allowed for said operator.
Statements are made of expressions, which may be simple or complex.
Loops are used to perform the same set of statements multiple times.
There are two types of workspaces: Local and Global.
Functions are packets of statements that can be used repeatedly.
OpenMatrix statements persist in .oml files.
This section describes files that can be manipulated by the OpenMatrix Language.
There are two types of errors: parse-time, and run-time.
Warning messages are similar to error messages in that they are output into the console or command window.
Create 2D and 3D plots and control their style and appearance.
Objects in OML are defined using the classdef keyword. This creates a blueprint for an object but does not actually create (instantiate) anything.
The Reference Guide contains documentation for all functions supported in the OpenMatrix language.
インストール済みのTwin Activateライブラリにあるすべてのブロックについて説明します。
Provides information about developing and simulating models through the Twin Activate Application Program Interface.
このページでは、デフォルトのショートカットを一覧表示します。
この用語集には、本ソフトウェアに関連する主要な用語と定義が含まれています。
よくある質問リスト
