ReferenceCurrentSource
Variable polyphase AC current with reference angle input
Modelica/Electrical/QuasiStatic/Polyphase/Sources
This model describes m variable current sources, with m complex signal inputs,specifying the complex current by the complex RMS voltage components.Additionally, the frequency of the current source is defined by a real signal input.m single-phase VariableCurrentSources are used.
See also
SinglePhase.VoltageSource,VoltageSource,VariableVoltageSource,CurrentSource.
mo_m | m | Number of phases | Scalar |
mo__modifiers/varname | Variable name | Cell of strings | 'abs_v' | |
mo__modifiers/value | Value |
plug_p | implicit | Positive quasi-static polyphase plug | input | 1 |
plug_n | implicit | Negative quasi-static polyphase plug | output | 1 |
gamma | implicit | Reference angle of current source | input | 2 |
I | implicit | input | 3 |
