This tutorial will guide you through the process of connecting a device (a Lamp) to SmartWorks and sending data to store it and implement simple business logic.
This tutorial will guide you through the process of connecting your ESP8266 and DHT10 sensor to SmartWorks to control the board LED light and monitor the surrounding humidity.
Stream Processing is a method of tracking and analyzing streams of information of an event, and eventually obtaining useful structured
conclusions out of that raw information.
SmartWorksEdgeOps is a set of tools for building, maintaining and continuously improving code in resource constrained devices at the
edge of smart connected ecosystems.
Read step-by-step tutorials to learn and manage SmartWorks.
Quickstart Tutorial
Motion Detection System Using a Raspberry Pi
This tutorial will guide you through the process of creating a project with the Raspberry Pi and connecting it to the SmartWorks platform.
Build Your Arduino Blink Project
This tutorial will guide you through the process of connecting your Arduino board to the SmartWorks platform and control the on-board LED blink.
Connect Your ESP8266 and DHT10 with SmartWorks
