[7] System Administration
Panopticon Real Time system administration is done on the following pages of the System tab.
| Page | Description |
System Settings |
Allows you to view the license and server information. |
Allows you to view and manage real-time plugin subscriptions. |
Allows you to view, refresh, clear, or delete caches that are currently running on the server. |
Allows you to set the logging level and view logs. Also, pause or resume logging, and copy or clear logs. |
Allows scheduling of email send outs and extracting of data. |
Allows you to view and manage logged in users. |
Allows you to add API Tokens that returns a key used for authorizing requests to the server. |
Allows to add fonts that can be used in a part or the workbook. |
