[15] PCLI: Command Utilities for Panopticon Real Time
Panopticon Real Time is supplied with a command line utility PCLI.
This supports the following:
Clears the cache on a Panopticon Real Time. |
Troubleshoot the plugins that this program utilizes. |
publish |
Prints program (and optionally server) version and exits. |
Use ‘help <command>’ to get help on a specific command. |
Upgrades specified workbook to the newest version. |
Updates workbook data tables with missing schema information. |
Export workbook data sources. |
Converts old permission files to the new format. |
Migrates all usages of the Database connector to JDBC Legacy connector in the given workbook/directory of workbooks. |
Updates workbook data tables with mock data based on the stored schema. |
Allows encryption of either a single text or an entire .properties file. |
Allows decryption of either a single text input or an encrypted .properties file. |
Summary help is displayed through: [pcli-folder]>bin/pcli help
More detailed help is displayed through: [pcli-folder]>bin/pcli help [command]
