Publishing a Workbook to Panopticon Real Time
Publishes a workbook to Panopticon Real Time.
| Option | Description |
-f, --force |
Overwrite existing workbook on server. Syntax example: bin/pcli publish -w "workbook" -d -u "http://username:password@host:port/app_name/" -n "name" -f |
-w, --workbook |
The workbook file to publish. Syntax example: bin/pcli publish -w "workbook" -u "http://username:password@host:port/app_name/" |
-d, --dataFiles |
Find and upload data files used by workbook. |
-u, --url |
URL to Panopticon Real Time, syntax: bin/pcli publish -w "workbook" -d -u "http://username:password@host:port/app_name/" |
-n, --name |
Publish workbook with a different name. Syntax example: bin/pcli publish -w "workbook" -d -u "http://username:password@host:port/app_name/" -n "name" |
--local |
Publishes workbook by file copy, instead of HTTP, for use when server exists on the local system. Specifies target file location path including file name. If the server is running, the application pool must be recycled after publication. |
-cp |
Java classpath. Syntax example: ‘bin/pcli publish -w "workbook" -u "http://username:password@host:port/app_name/"' |
Command example: bin/pcli publish -w "How To Actions.exw" -d -u "http://username:password123@localhost:8080/panopticon" -n "Published by pcli" -f
