MigrateDatabaseToJDBC
Migrates all usages of the Database connector to JDBC Legacy connector to enable editing in the Web Client.
| Option | Description |
-w, - workbook |
Full path of workbook to migrate. |
-o, --output |
Output path. Can be used together with the '-w' option, when a new name to migrated workbook is needed. Output directory should exist. |
-od, --output-directory |
Output directory path. Output directory should exist. |
-wd, --workbook-directory |
Directory of workbooks to upgrade. |
Command example: bin/pcli migratedatabasetojdbc -w "E:\ \Workbooks\Database.exw" -o "E:\MigratedWorkbooks\JDBC.exw"
