Table Column Filtering
Instead of using a Filter Box, you can right-click on a table column header and select Filter to perform filtering.
The dialog box that displays will depend on the data column type.
- For numeric columns
Enter the numeric range filter then click either:
- Include to include the entered range, or
- Exclude to exclude the entered range.
- For text columns
This text entry box is the same as the filter in lncude/Exclude mode.
When you enter a value in the Free Text Entry box, you can click
to clear the field.
- For time columns
Enter the time range filter then click either:
When a filter is applied on the table columns,
filter icons appear at these places:
- To the right of the table column header
Numeric column:
Text column:
- Table Header Control
- Dashboard toolbar
- Table Column Filter dialog
Numeric column:
Text column:
To remove the filter:
- Click
. - For text columns, you can also click
Also, Show Active Filters
icon displays on the Table Header Control. This allows viewing of all the active filters on the dashboard and its visualizations.
