Connector for Solace
The Solace connector allows connection to Solace’s message bus on a real time streaming basis. Specifically, the connector allows Panopticon to subscribe to messages that are published in particular topics in Solace and onsequently, perform operational analytics.
- Enter the connection details:
Property Description Host
Solace host address.
VPN Name
Message VPN name. Default is default.
User Id
The user Id that will be used to connect to Solace.
Password
The password that will be used to connect to Solace.
- Enter the Topic or the queue's physical name.
- Select the Message Type.
Aside from the JSON, Text, and XML message types, Protobuf and SDTMap are also supported in Solace.
If Protobuf is selected, confirm the Decimal Separator, and enter the Schema Name and Type Name.
Then click
to select the File Descriptor (.desc file) in the Open dialog.
Property Description Schema Name
The Protobuf schema.
Type Name
The message of Protobuf type that will be sent to Kafka.
File Descriptor
The FileDescriptorSet which:
Is an output of the protocol compiler.
Represents a set of .proto files, using the --descriptor_set_out option.
For SDTMap, confirm the Decimal Separator.
- Select either the dot (.) or comma (,) as the Decimal Separator.
NOTE: Prepend 'default:' for the elements falling under default namespace.
- Click
to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
This also populates the Id Column with the set of columns, of arbitrary type, that can be concatenated to form a unique row identifier.
- You can also opt to load or save a copy of the column definition.
- Click
to add columns to the Solace connection that represents sections of the message. Then enter or select:
Property Description Name
Fix Tag/JsonPath/Text Column Index/XPath
The Fix Tag/JsonPath/Text Column Index/XPath of the source schema.
Date Format
Enabled
Determines whether the message field should be processed.
Filter
Defined parameters that can be used as filter. Only available for JSON, Text, and XML message types.
NOTE: To parse and format times with higher than millisecond precision, the format string needs to end with a period followed by sequence of upper case S. There can be no additional characters following them.
For example: yyyy-MM-dd HH:mm:ss.SSSSSS
To delete a column, select
or for all the column entries select the topmost
, then click .
Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
For this section:
Refer to Define Real-Time Settings for more information.
