Defining the Message Type in Data Sources
You can select the message type that specifies the format of the data within the message in ActiveMQ, Google Cloud PubSub, MQTT, RabbitMQ, Solace, and WebSocket connectors.
- Select the Message Type:
- FIX
- JSON
If JSON is selected, enter the Record Path which allows the identification of multiple records within the JSON document (e.g., myroot.items.item) and select the Array Handling setting.
- Text
If Text has been selected, confirm the Decimal Separator, Text Qualifier, Column Delimiter, and if the first row of the message includes column headings.
- XML
- FIX
- Define or set the columns that represent the sections of the message.
Property Description Name
Fix Tag/JsonPath/Text Column Index/XPath
The Fix Tag/JsonPath/Text Column Index/XPath of the source schema.
Date Format
Enabled
Determines whether the message field should be processed.
NOTE: To parse and format times with higher than millisecond precision, the format string needs to end with a period followed by sequence of uppercase S. There can be no additional characters following them. For example: yyyy-MM-dd HH:mm:ss.SSSSSS.
To delete a column, select
, or for all the column entries select the topmost
, then click .
