Connector Availability
Connectors are available in Add Data Table Wizard, Workbook Internal Data Table Editor, Data Table Editor, and Joined Data Table Editor. Although the interfaces may be different, the fields or properties to configure for a connector is similar.
Below is the list of File/URL data sources in the Workbook Internal Data Table Editor layout.
Click on the other data source group tabs to select database and streaming data sources. Tap the Show Legacy Connectors slider to display the legacy connectors you can select.
The Search box allows you to immediately find a particular data source that you want to use. Click a data source group tab then enter the name of the data source in the Search box.
