Adding Calculated Columns
NOTE:
  • User defined columns can only be added when there is an available data source.
  • The user-defined columns are added to the topmost data source in the Data Sources list or in the joined or combined data source.
  • An auto key can only be created once.
  • Ranking requires a numeric source column.
  • Time bucketing requires a time source column and each source column can only be used once.
  • Numeric bucketing requires a numeric source column.
  • Adding Text GroupingsText grouping requires a text source column.
  • The added user-defined column displays on the Data Preview with a pen symbol    which allows its modification.
(c) 2013-2025 Altair Engineering Inc. All Rights Reserved.
