Adding a User Group
To add a user group
On the Navigation Tree, click Rights and Privileges, and select User Groups.
Click
on the User Groups page. The User Group page containing the following items appears:-
User Group Name: Enter a unique name of a new user group.
Description: Optionally, enter any text defining the user group.
Alias: Active Directory group name. This field is filled out automatically if you apply user group importing.
NOTE: Alias is only available when the Enable Active Directory Group Lookup checkbox in Active Directory is selected.
Privileges: By selecting check boxes, an administrator can grant the following privileges:
Administrator: Allows the user to log on to MSAdmin.
Automator Administrator: Allows the user full administration.
Automator User: Allows the user to manage processes and jobs.
Can Edit Scripts: Allows the user to edit process scripts and script items for Visual Processes and Standard Processes, as well as project scripts (i.e., PreProcess, PostProcess, and Global). If unselected, the user cannot edit the properties of script items for existing processes; the user can only run the script and check the results.
Can Use Default Credentials: Allows the user to use the credentials defined in the Server Integration settings.
Automator Light User: Allows the user to partially manage processes and jobs.
Can Edit Schedules: Allows the user to add, edit, and delete schedules for Visual Processes and Standard Processes. Note that only the schedules whose processes are assigned to the user can be modified.
Can Delete Process Logs: Allows the selected user to delete the logs whose processes are assigned to them.
Members: Click this heading to expand hidden sections.
Available User Groups: Displays all available user groups from which you can select ones to assign to the current role. To add a user group, drag it from the left pane to the right pane.
Selected User Groups: The user groups in this pane will be assigned to the current role. To remove a user group, drag it from the right pane to the left pane.
Available Users: Displays all available users from which you can select ones to assign to the current role. To add a user, drag it from the left pane to the right pane.
Selected Users: The users in this pane will be assigned to the current role. To remove a user, drag it from the right pane to the left pane.
Members of: Click this heading to expand the hidden sections.
Available User Groups: Displays all available user groups from which you can select ones to assign the current user to. To add a user group, drag it from the left pane to the right pane.
Selected User Groups: The current user will be assigned to the user groups in this pane. To remove a user group, drag it from the right pane to the left pane.
Available Roles: Displays all available roles from which you can select ones to assign the current user to. To add a role, drag it from the left pane to the right pane.
Selected Roles: The current user will be assigned to the roles in this pane. To remove a role, drag it from the right pane to the left pane.
NOTE: The default user groups and roles available in the list of available user groups and roles for the new user are those specified in the New User Defaults settings in System Preferences under System Settings. See Groups and Roles.
Save: Click to save the new user group. In the Save/Edit Group dialog, click Yes to proceed with editing the user group's access rights and No to return to the User Groups page.
Clear: Click to clear all the boxes.
Cancel: Click to cancel the operation.
Copy Profile: Opens a dialog box where you can select a user group. All its settings will be copied. You can make the necessary changes.
Fill in the boxes of the page and click Save. The system saves the new user group to the database and displays the updated User Groups page, if the operation is completed successfully.
NOTE: After you have created a user group, you can assign access rights to it. For details refer to Assigning Access Rights.
