Deleting a Sort Order
When you delete a sort order, Monarch Classic removes the sort order name from the Sort Orders dialog. If the sort order is applied to the table at the time it is deleted, Monarch Classic re-displays the table in its natural order (the order that data was originally added to the Table window).
  1. Select Sorts from the Table Design ribbon.
  2. Select the sort you wish to delete on the Filters selector.
  3. Select Delete from the Table Design ribbon.
CAUTION: Monarch Classic has no undo facility. Once you have pressed Yes, then you cannot reverse the change. Prior to pressing Yes, however, you can press No to reverse the change.
© 2024 Altair Engineering Inc. All Rights Reserved.
