Deleting a Calculated Field
When you delete a calculated field, Monarch Classic removes the field from the table and deletes the calculated field definition.
Select Formula Field, Lookup Fields, Runtime Parameter Fields, or User Edit Fields on the Table Design ribbon.
The calculated fields are displayed on their own window. Select the field you wish to delete on the selector.
Select Delete on the Table Design ribbon.
