Overview: Sorting a Summary
In Monarch Data Prep Studio, the records in a summary are arranged in the order that they are extracted or imported. However, you may want to view the data in another order. To sort a summary table, you define a sort order and then apply it to the table. A sort order definition tells Monarch Data Prep Studio which fields to sort and the order, or direction, for each field (ascending or descending).
The following topics may prove helpful as you sort your summary tables in Monarch Data Prep Studio:
