Selecting a Sort to Apply to a Summary
Once you have created a named, you can use it to sort the data in your summaries.
The steps for applying a named sort to a summary are described in this section.
In the Analyze tab, select a summary from the Summary drop-down or create a new summary.
From the Sort drop-down, choose the named sort to apply to the summary you selected.
