Monarch 2021 Features
The bullets below highlight some of the newest features available in Monarch 2021.0.
Monarch 2021.1
Monarch Classic Highlights
Command Line interface support for bulk sample line redaction and project/model/workspace credentials scrubbing
Improved sizing in the Summary Add/Remove Fields window
Ability to edit Project and Model descriptions
Various bug fixes
Various UI/UX improvements
Data Prep Studio Highlights
All Filters export (analogous to Monarch Classic)
All Summaries export (analogous to Monarch Classic)
Summary Export splitting into separate files or tables based on key values (analogous to Monarch Classic)
Import supported Summary metadata from Monarch Classic Models
Named Sorts in Analyze (analogous to Monarch Classic)
Import named sorts from Monarch models
Color change to indicate table changes and count in the table selector
Open CSV files via the Excel and Worksheet Design connectors
Allow Sort Transforms to be discarded without affecting the table hierarchy
Show Tables dialog for Excel, Access and SAS Transport File Format (XPORT) Version 5 exports
Append data option for Qlik QVX export
Improved IP V6 Support for various Connectors
Copy/Paste Trap in Worksheet Design
Summary Measure Format configuration
All-by-key & all-by-measure Summary views (analogous to Monarch Classic)
Various bug fixes
Various UX/UI improvements
Monarch 2021.0
Improvements in Summary-related behavior
Cancellable Report Search
Various bug fixes
Support for named filters
Support for report/template colors
Implementation of Report View
Integration of Monarch Table Extractor with Data Prep Studio
ServiceNow and Snowflake connectors
Report Design improvements (e.g., Find in report, position indicator, cancelable search)
Updated Command Line Interface
Various bug fixes
NOTES:
If you have a license for Monarch Complete, you will have access to both Classic and Data Prep Studio features.
If you have a license for Monarch Classic, you will have access to Classic features only.
Contact Altair Sales if you would like to upgrade your license to gain access to all of the features listed above and more.
Related links
