Connector Dialog for Snowflake
NOTE: This connector requires a Java Virtual Machine (JVM) to function properly.
The Snowflake connector dialog includes the following fields and settings:
Field
Connection
Account Name
The full name of your account and the region where it is hosted. The full account name may include additional segments that denote region and cloud platform.
Authentication Method
Determines the authentication method to be used during the course of the session.
Select the method to use from the drop-down provided:
  • OAuth
  • User ID/Password
Required connection fields (in bold) will depend on the authentication method you select.
User Name
A valid User ID required to log-on to the data source.
Password
A valid Password required to log-on to the data source. This password must match the User ID above.
Client ID
Enter the client ID key for your application when authenticating to REST endpoints with OAuth 2.0 enabled (AuthenticationMethod=OAuth2).
Client Secret
Enter the client secret for your application when authenticating to REST endpoints with OAuth 2.0 enabled.
Important: The client secret is a confidential value used to authenticate the application to the service. To prevent unauthorized access, this value must be securely maintained.
Authorization URI
Enter the endpoint for obtaining an authorization code from a third-party authorization service for OAuth 2.0 implementations.
Token URI
Enter the endpoint for retrieving access tokens when OAuth 2.0 authentication is enabled.
Redirect URI
Enter the data range that will be used to filter the Google Analytics rows.
Scope
Enter a space-separated list of OAuth scopes that limit the permissions granted by an access token.
Token
Enter the access token used to authenticate to REST endpoints with OAuth 2.0 enabled. Typically, this option is configured by the application; however, in some scenarios, you may need to secure a token using external processes. In those instances, you can also use this option to set the access token manually.
Note: You can use the Copy/Paste icon  to easily paste or copy the token value to or from the dialog box.
Database Name
Enter or select the database you want to connect to.
For some data sources, you need to click Fetch Databases first to populate the database drop-down list.
Warehouse
The username provided for authentication with the Snowflake database.
Schema
Other Connection Options
Connection options required to connect to the data source.
If you need multiple string connection options, separate these by a semi-colon. However, you can only enter up to a maximum of 512  characters into this text box.
Available options and valid values are discussed here.
Reset Connection
Check this box to reset the OAuath connection and fetch new access tokens.
Test Connection
Click to initiate a connection and test the values you have entered. If there are errors, messages will be displayed beside this button.
Note: You can right-click on an error message to display a Copy button. Select the button to copy the error message.
Tables & Views
Tables & Views
Allows you to load, and then select, the tables from your database by manually selecting from a list.
To load tables and views via search and select:
  1. Select the Tables and Views tab.
  2. Click Fetch Databases to fetch the list of databases and populate the drop-down list. Select a database.
  3. Click Load Tables to load a list of predefined tables or views. These are displayed on the Tables List (at the left side of the dialog box).
  4. Select a table from the Tables List.
    The columns of the table are displayed in the Columns List (beside the Tables List).
  5. Select the columns to add to your data table by checking the column boxes.
Note: If you wish to add a duplicate column, select this column from the Add a duplicate column drop-down list provided.
To select a column
Check the boxes beside the columns you want to use. If you want to use all columns, check the Column box on the header.
To aggregate columns
If the data returned is to be aggregated, check the Aggregate box on the header, then select the aggregation method you want to use for each column.
The following aggregation methods are possible for each data type:
To filter columns
If the data returned are to be filtered, check the Apply Filter on the header. Then, for each column, select a filter method from the filter drop down and then enter the filter value in the Filter Value box.
Notes:
  • If you are unsure about the filter value format of the Date field, hover on the Filter Value text box to display a tooltip hint:
  • Some data sources require case-sensitive filter values. Refer to this list to check which data sources have case-sensitive filters.
  • To load tables and views using an SQL Query, select the Query tab.
Query
Query
Allows you to load, and then select, the tables from your database by entering a SQL Statement.
If you already selected Tables and Views, this box is updated to show the corresponding  SELECT * FROM TABLE query.
If you want to define the query, enter the SELECT, EXEC, and/or WITH statements to execute.
Notes:
  • To minimize security risks and prevent SQL Injection attacks:
    • Only Select, Exec, and/or With statements are allowed.
    • The following are NOT allowed:
      • Comment characters ( -- )
      • Semi-colons ( ; )
  •  In cases where you need to use a series of SQL statements with or without comments, we recommend you use stored procedures to contain these statements. The stored procedure can then be executed by using the EXEC statement in the Query form.
  • The Preview Data and OK buttons are only enabled if the connection is active and the query is correct. Check your connection or your query if one of the buttons is disabled.
Preview Data
Click to fetch data using the credentials and criteria you have specified. This allows you to confirm your connection, ensure you have connected to the correct table, check your query, and verify the information that will be loaded.
Notes:
  • Only 10 records are displayed to allow you to verify that you are selecting the correct data. This limit prevents system slow down.
  • The button is only enabled if the connection is active and the query is correct. Check your connection or your query if one of the buttons is disabled.
OK/CANCEL
Select OK to establish the connection and fetch data or Cancel to close the dialog.
The state of the OK and PREVIEW buttons provides a handy status about the state of your connection:
  • The OK and PREVIEW DATA buttons are enabled as soon as the required fields have been entered and verified. This usually means a connection to the data source has been established and a table has been selected.
  • The OK button is disabled when an update is made that can lead to an invalid result (e.g. the User Name or Password is not valid, or the the SQL statement in the Query tab is invalid). In such cases, use  PREVIEW DATA to validate that data can be retrieved. If this fails verify your connection information or query until data can be retrieved.
Note:
If you encounter a token expired error while the connection is in use, reset and test the connection, from the Connection Tab:
  1. Check the Reset Connection box.
  2. Select Test Connection.
© 2025 Altair Engineering Inc. All Rights Reserved.
