Release Notes 2023.0
The release notes provide details about the new features and enhancements in AMM 2023.0
Enhancements
Import
  • You can now set the path to ALTAIR MATERIAL DATA CENTER for import raw data
  • Use the Import button to open the AMDC Plug in and select a material.
Equidistance: Select the count of steps and if you like to use it in an equidistant way mark the checkbox.
Create curves at different times as csv file
Button splitted up to Create Card and Advanced
Material Card fields are adjusted and wider for long filenames
Simulation reload existing simulation runs by using button L
Name of the used extrapolated curve is stored inside of the material card
