Known Issues
This section outlines current limitations and areas for improvement identified in this release:
Pressure Dependence Fitting for IKV and Schmidt Models
Summary: Models for pressure dependence are in early stages and lack maturity.
Workaround: Users can manually edit parameters as needed to achieve desired results.
Compressible Hyperelastic (HE) Fitting Performance is Slow
  • Summary: Slow initial fitting process may take longer than expected.
    Workaround: Performance improves significantly when switching between results after initial fitting.
  • Summary: Replacing test data triggers a refit process for multi-curve models, which can increase processing time.
Specific Volume Fitting False-Error Detection
Summary: Automated data checks can be overly sensitive, occasionally flagging false errors.
Workaround: As a workaround, parameter data can be imported directly using XLSX or CSV files for validation and correction.
