Add a Remote Service Using HyperXtrude Job Manager
Submit extrusion simulation on local or remote machines.
Creating a Remote Service
Note: You must first enable Use HyperXtrude Job
                Manager in Preferences > Inspire Extrude
                Run Options.
                Click the Run menu under the
                        Analysis tool.
                Click Add Server to add a remote server.
        Dialog to add a new service pops up. This dialog is prepopulated with default data to help in entering the correct paths.
 - Click Save to add the service.
 - Click Advanced to access the complete job manager setup.
Editing Service
                Right-click on the service, and click Edit.
Dialog to edit the service will pop up. - Click Save to update the changes.
Deleting Service
                Right-click on the service to remove, and click
                    Delete.
