Conservation of Mass
The finite element formulation of the Lagrangian form of the mass conservation equation is given by:
d ρ d t | x = ( ρ / V ) d V d t | x MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aadaWcaaqaaiaadsgacqaHbpGCaeaacaWGKbGaamiDaaaadaabbaqa aiaadIhaaiaawEa7aiabg2da9iabgkHiTmaabmaabaGaeqyWdiNaai 4laiaadAfaaiaawIcacaGLPaaadaWcaaqaaiaadsgacaWGwbaabaGa amizaiaadshaaaWaaqqaaeaacaWG4baacaGLhWoaaaa@4D14@
When transformed into the ALE formulation it gives:
ρ t ξ ω i ν i ρ x i ζ + ρ ν κ x κ ζ = 0 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaSaaaeaacq GHciITcqaHbpGCaeaacqGHciITcaWG0baaamaaeeaabaWaaSbaaSqa aiabe67a4bqabaaakiaawEa7aiabgkHiTmaabmaabaWaaeWaaeaacq aHjpWDdaWgaaWcbaGaamyAaaqabaGccqGHsislcqaH9oGBdaWgaaWc baGaamyAaaqabaaakiaawIcacaGLPaaacqGHflY1daWcaaqaaiabgk Gi2kabeg8aYbqaaiabgkGi2kaadIhadaWgaaWcbaGaamyAaaqabaaa aOWaaqqaaeaadaWgaaWcbaGaeqOTdOhabeaaaOGaay5bSdaacaGLOa GaayzkaaGaey4kaSIaeqyWdi3aaSaaaeaacqGHciITcqaH9oGBdaWg aaWcbaGaeqOUdSgabeaaaOqaaiabgkGi2kaadIhadaWgaaWcbaGaeq OUdSgabeaaaaGcdaabbaqaamaaBaaaleaacqaH2oGEaeqaaaGccaGL hWoacqGH9aqpcaaIWaaaaa@67AA@
Applying a Galerkin variation form for the solution of Equation 2:
v Ψ ρ t ξ ω i ν i ρ x i ζ + ρ ν κ x κ ζ = 0 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaa8quaeaacq qHOoqwaSqaaiaadAhaaeqaniabgUIiYdGcdaqadaqaamaalaaabaGa eyOaIyRaeqyWdihabaGaeyOaIyRaamiDaaaadaabbaqaamaaBaaale aacqaH+oaEaeqaaaGccaGLhWoacqGHsisldaqadaqaamaabmaabaGa eqyYdC3aaSbaaSqaaiaadMgaaeqaaOGaeyOeI0IaeqyVd42aaSbaaS qaaiaadMgaaeqaaaGccaGLOaGaayzkaaGaeyyXIC9aaSaaaeaacqGH ciITcqaHbpGCaeaacqGHciITcaWG4bWaaSbaaSqaaiaadMgaaeqaaa aakmaaeeaabaWaaSbaaSqaaiabeA7a6bqabaaakiaawEa7aaGaayjk aiaawMcaaiabgUcaRiabeg8aYnaalaaabaGaeyOaIyRaeqyVd42aaS baaSqaaiabeQ7aRbqabaaakeaacqGHciITcaWG4bWaaSbaaSqaaiab eQ7aRbqabaaaaOWaaqqaaeaadaWgaaWcbaGaeqOTdOhabeaaaOGaay 5bSdaacaGLOaGaayzkaaGaeyypa0JaaGimaaaa@6E11@
Where, ψ is the Weighting function.
Using a finite volume formulation
Where, ψ =1
ρ = constant density over control volume V MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvaaaa@36D1@ .
Therefore:
V ρ t d V + V ρ ν K x K d V = 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aadaWdrbqaamaalaaabaGaeyOaIyRaeqyWdihabaGaeyOaIyRaamiD aaaacaWGKbGaamOvaiabgUcaRmaapefabaGaeqyWdihaleaacaWGwb aabeqdcqGHRiI8aaWcbaGaamOvaaqab0Gaey4kIipakmaalaaabaGa eyOaIyRaeqyVd42aaSbaaSqaaiaadUeaaeqaaaGcbaGaeyOaIyRaam iEamaaBaaaleaacaWGlbaabeaaaaGccaWGKbGaamOvaiabg2da9iaa icdaaaa@5447@
Using the divergence theorem leads to:
V ρ t d V + S ρ ( ν j n j ) d S = 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aadaWdrbqaamaalaaabaGaeyOaIyRaeqyWdihabaGaeyOaIyRaamiD aaaacaWGKbGaamOvaiabgUcaRmaapefabaGaeqyWdihaleaacaWGtb aabeqdcqGHRiI8aaWcbaGaamOvaaqab0Gaey4kIipakmaabmaabaGa eqyVd42aaSraaSqaaiaadQgaaeqaaOGaeyyXICTaaGPaVlaayIW7ca WGUbWaaSbaaSqaaiaadQgaaeqaaaGccaGLOaGaayzkaaGaamizaiaa dofacqGH9aqpcaaIWaaaaa@5889@
Further expansion gives:
d d t v ρ d V = s ρ ( w j v j ) n j d S m a s s f l u x MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aadaWcaaqaaiaadsgaaeaacaWGKbGaamiDaaaadaWdrbqaaiabeg8a YjaadsgacaWGwbGaeyypa0Zaa8quaeaadaagaaqaaiabeg8aYnaabm aabaGaam4DamaaBaaaleaacaWGQbaabeaakiabgkHiTiaadAhadaWg aaWcbaGaamOAaaqabaaakiaawIcacaGLPaaacaWGUbWaaSbaaSqaai aadQgaaeqaaOGaamizaiaadofaaSqaaiaad2gacaWGHbGaam4Caiaa dohacaaMc8UaamOzaiaadYgacaWG1bGaamiEaaGccaGL44paaSqaai aadohaaeqaniabgUIiYdaaleaacaWG2baabeqdcqGHRiI8aaaa@5E39@
This formula is still valid if density ρ is not assumed uniform over volume V MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvaaaa@36D1@ .
Figure 1. Mass Flux Across a Surface
The density, ρ i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyWdi3aaS baaSqaaiaadMgaaeqaaaaa@38D0@ , is given computed:
ρ i = 1 2 ρ I { 1 + η   s i g n ( ϕ i ) } + 1 2 ρ J { 1 η   s i g n ( ϕ i ) }
Where, 0 η 1 is the upwind coefficient given on the input card.
If η =0, there is no upwind.
Therefore, ρ i = ρ I + ρ J 2 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyWdi3aaS baaSqaaiaadMgaaeqaaOGaeyypa0ZaaSaaaeaacqaHbpGCdaWgaaWc baGaamysaaqabaGccqGHRaWkcqaHbpGCdaWgaaWcbaGaamOsaaqaba aakeaacaaIYaaaaaaa@4117@ .
If η =1, there is full upwind.
The smaller the upwind factor, the faster the solution; however, the solution is more stable with a large upwind factor. This upwind coefficient can be tuned with parameter from /UPWIND keyword (not recommended, this keyword has been obsolete as of version 2018).
For a free surface: ρ J MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyWdi3aaS baaSqaaiaadMgaaeqaaaaa@38D0@ = ρ I MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyWdi3aaS baaSqaaiaadMgaaeqaaaaa@38D0@
