ALE Kinematic Conditions
Boundary Conditions
Boundaries with Lagrangian materials are declared automatically Lagrangian.
Nodes can be declared Lagrangian.
Constraints can be applied separately or simultaneously on:
- Material velocity
- Grid velocity
These constraints can be applied in one or several directions of a skew reference frame.
When the flag is set to 1, boundary condition is activated with global reference frame or skew
reference frame.Figure 1.
i = DOF with respect to global reference frame or skew reference frame
VELOCITY: Vi = 0
ACCELERATION: π i = 0
The boundary conditions can be changed during Engine runs with /BCS or /BCSR Engine options.
ALE Links
An ALE link is identical to a rigid link. The secondary node sets' grid velocity can be controlled by two main nodes, M1 and M2.
There are three options to choose from:
- Option 0
- Velocity is linearly interpolated with respect to order of
input.
- Option 1
- Velocity is set to maximum absolute velocity of main
nodes.
- Option 2
- Velocity is set to minimum absolute velocity of main
nodes.
