/BULKPROP (Obsolete)
Optimization Keyword Defines Bulk Format Data to be used as the conversion data for Radioss property data (/PROP) into the intermediate OptiStruct input file during Design Optimization.
| /BULKPROP/prop_ID | |||||||||
| title | |||||||||
| Bulk Format Data | |||||||||
Definition
| prop_ID | Property
identifier (Integer) |
| title | Property
| Bulk Format Data | Bulk Format Data to be used as the conversion data for Radioss property data (/PROP) into the intermediate OptiStruct input file. |
The Radioss property entry (/PROP)
defined in the Starter input file with prop_ID = 6 will be converted into OptiStruct
PSHELL
entry.
/BULKPROP/6
Conversion of prop_ID=6
PSHELL,6,1,1.0,1,,1,0.79
- All element properties in OptiStruct are supported in /BULKPROP.
