CAD Interface
New Features
- ECAD Reader Support
- HyperMesh 2025.1 now includes support for ECAD file formats. With this enhancement, you can import and work with a broader range of electronic design data.
Enhancements
- Third-Party Library Support
- HyperMesh 2025.1 integrates support for multiple third-party libraries:
- CT 2022 SP9
- CT 2022 SP9 adds support for NX 2406 and CREO 11.
- CT 2024 SP3
- CT 2024 SP3 adds support for 2024 3DXML, NX2412, CREO 11, CATIA V5 R34, and SolidWorks 2024.
- JT Reader Update
- The JT Reader open libraries option has been updated to version 11.6.
- NX Native Reader Updates
- Support for NX 2412 has been added to the native reader.
- IFC Reader Updates
- A new option, midline midsurface, has been introduced. The midline midsurface option applies exclusively to components with geometry defined as swept solids, not BREP. When enabled, you can use the midline midsurface option to import only the axis representation, a 2D planar cross-section and its extrusion path, without generating the full solid geometry.
Resolved Issues
- HyperMesh 2025.1 has enhanced support for reading PLY systems using the new CATIA CPD file format, which was not working in previous releases.
- An issue where CATIA V5 files containing composite details not being imported correctly has been resolved. This fix ensures more reliable handling of complex composite data across supported formats.
