Align to Surfaces
Use the Surfaces tool to project nodes, elements, lines and points onto a surface along either a user-defined direction or the normal to the surface selected.
  1. From the secondary ribbon, click the Surfaces tool.
  2. Select nodes, elements, lines, or points as source entities to be projected onto the target surface.
  3. Use the Target selector to choose the target surface.
  4. Click
