Align to Lines
Use the Line tool to project nodes or points to a line along a user-defined direction or the normal to the line selected, then remap or offset over selected reference entities.
                From the secondary ribbon, click the Lines tool.
 - Select ordered nodes, FE edges, or points as source geometry to align/project to onto target entities.
 - Check Use end nodes to auto-detect end nodes based on your source selection and align between them. Otherwise, select target entities to align to.
                Click
                    Along Vector to define a single direction using the Vector
                    tool.
                All of the entities are projected along this direction. -
                Use the icons in the microdialog further refine the
                    alignment:
 - Remap projected nodes to they are dispersed
                        evenly over the length of the line.
 - If two nodes or targets are selected, toggle
                        to make the connecting line finite/infinite.
 - Offset the target line by the specified
                            value
                Click
- Project source nodes on to a target line
 - Project nodes on to a smooth line (smooth lines can be defined using the
                        location entity)
Figure 3.
 - Align nodes between start and end nodes
Figure 4.
 - Align nodes with respect to reference nodes
Figure 5.
 - Align + Remap
Figure 6.
 - Align + Offset
Figure 7.
