The Options dialog, Build Model option allows you to set the
standard include files and enable/disable the wizard related menu items in the menu
bar.
To open this dialog, select Options from the Tools menu, and then
click Build Model on the tree.Figure 1. Options dialog - Build Model
The options available include:
Standard Include
The standard include file is an include file which
is read in when MotionView is launched or a new
MotionView client is created. This file defines the
default options such as Units, Gravity, and other solver options. A similar way to
specify standard include is available in Model > Set Wizard Paths, however this method is likely to be discontinued in future
releases.
Use standard include defined in preference file
Activate this check box to use the default standard include file as specified
in the preference_mbd.mvw file.
Uncheck this check box to
activate the Standard include file file browser.
Allows you to use the file browser to specify a standard include file other
than the default file.
This option will be disabled if the Use standard include
defined in preference file check box is activated (see above).
Legacy Support
Enable wizard support
Use this option to activate or deactivate wizard related options in the Model
and Analysis menus.
Unchecking this check box will disable the Assembly Wizard,
Attachment Wizard, Set Wizard Path (under Model), and Task Wizard (under
Analysis).
Create a separate definition when modifying a shared
instance
Use this option to control how shared instances should be handled while
modifying them:
This option is activated by default, indicating that any modification to a
shared instances will result in a separate definition.
Deactivate this option to retain the sharing and apply a change to one
instance to the other shared instances also.
See the Managing Shared Definitions topic for additional
information.
Use updated symmetry
Using this option allows a truly symmetric rigid body to be represented
(where properties represent bodies which are mirror with regard to each other
about the Global ZX plane).
Click on background selects Ground Body
Use this option to select the Ground Body by clicking on the
background.
Allow CAD feature recognition for picking
Use this option to create and select certain types of entities in a collector
by picking an edge or surface of certain Graphic entities.
