TABDMP2
Bulk Data Entry Defines modal damping as a tabular function of mode index.
TABDMP2 TID TYPE
ms1 me1 g1
ms2 me2 g2
etc. etc. etc.
TABDMP2 1001
1 0.010
2 8 0.124 ENDT
Definition
TID Table identification number.
No default (Integer > 0)
TYPE Damping units type. 7
G (Default)
Units of equivalent viscous damping.
CRIT
Units of fraction of critical damping.
Q
Units of amplification or quality factor.
msi Index of the lowest mode of a range.
No default (Integer ≥ 1)
mei Index of the highest mode of a range. 5
blank (Default)
Damping is applied only to the mode defined in msi .
(Integer ≥ msi )
gi Fraction of critical damping.
No default (Real > 0.0)
  1. Modal damping tables must be selected in the Subcase Information section, using the SDAMPING entry. This form of damping is supported in Modal Transient, Modal Frequency Response Analysis, Modal Complex Eigenvalue Analysis and Response Spectrum Analysis.
  2. A METHOD statement must be present in the SUBCASE.
  3. At least one continuation entry must be specified.
  4. The end of the table is indicated by the existence of ENDT in either of the two fields following the last entry. An error is detected if any continuations follow the entry containing the end-of-table flag ENDT.
  5. When the mei field is left blank, it is assumed to be the same as and the damping is applied only to a single mode.
  6. The KDAMP option, on the PARAM card, may be used to switch between viscous and structural damping. Viscous is the default and is used when PARAM, KDAMP is not present.
    KDAMP
    Results
    1 (Default)
    B matrix
    -1
    (1+ig)K matrix
  7. If TYPE is G or blank, the damping values gi are in units of equivalent viscous damping as:
    bi=giωiki
    If TYPE is CRIT, the damping values gi are in units of fraction of critical damping C/C0 .
    If TYPE is Q, the damping values gi are in the units of amplification or quality factor, Q. These constants are related by the following equations:
    CC0=g2
    Q={1(2CC0)1g
  8. To achieve identical displacements in Modal frequency response or Modal transient analyses when the SDAMPING is used instead of PARAM, G, the steps described here can be followed:
    • The TYPE field in the TABDMP1 or TABDMP2 Bulk Data Entry should be set to CRIT. This TABDMP1 Bulk Data Entry is referenced by the SDAMPING Subcase Information Entry.
    • Set the damping value (field gi ) in the TABDMP1 or TABDMP2 Bulk Data Entry equal to half of the value of PARAM, G (set to the constant value to C/C0 ).
    • Set PARAM, KDAMP,-1
