TABDMP1
Bulk Data Entry Defines modal damping as a tabular function of natural frequency.
TABDMP1 TID TYPE FLAT
f1 g1 f2 g2 f3 g3 f4 g4
f5 g5 etc. etc. etc. etc. etc. etc.
TABDMP1 2
2.5 0.01057 2.6 0.1362 ENDT
TID Table identification number.
No default (Integer > 0)
TYPE Damping units type.
G (Default)
Units of equivalent viscous damping.
CRIT
Units of fraction of critical damping.
Q
Units of amplification or quality factor.
FLAT
Specifies the handling method for y-values outside the specified range of x-values in the table.
=0 (Default)
If an x-value input is outside the range of x-values specified on the table, the corresponding y-value look up is performed using linear extrapolation from the two start or two end points.
=FLAT or 1
If an x-value input is outside the range of x-values specified on the table, the corresponding y-value is equal to the start or end points, respectively.
fifi Natural frequency value in cycles per unit time. Must be specified in either ascending or descending order, but not both.
May be ignored by placing SKIP in either of the two fields used for that entry.
No default (Real ≥ 0.0)
gigi Damping value.
No default (Real)
  1. Modal damping tables must be selected in the Subcase Information section, using the SDAMPING entry. This form of damping is supported in Modal Transient, Modal Frequency Response Analysis, Modal Complex Eigenvalue Analysis and Response Spectrum Analysis.
  2. A METHOD statement must be present in the SUBCASE.
  3. For example, in Figure 1 discontinuities are allowed only between points f2f2 through f7f7 . Also, if gg is evaluated at a discontinuity, then the average value of gg is used. In Figure 1, the value of gg at f=f3f=f3 is g=(g3+g4)/2g=(g3+g4)/2 .
  4. At least one continuation entry must be specified.
  5. The end of the table is indicated by the existence of ENDT in either of the two fields following the last entry. An error is detected if any continuations follow the entry containing the end-of-table flag ENDT.
  6. For FLAT=0 (default), TABDMP1 uses the algorithm:
    g=gT(f)g=gT(f)
    Where, ff is input to the table and gg is returned.
    The table look-up gT(f)gT(f) is performed using linear interpolation within the table and linear extrapolation outside the table using the two starting or end points (Figure 1). No warning messages are issued if table data is input incorrectly.
    Figure 1. Example of Table Extrapolation and Discontinuity
    For FLAT=1, the same algorithm as FLAT=0 is used, except that values outside the range are not extrapolated. The corresponding start or end point y-values are used for all y-values outside the range.
  7. The KDAMP option, on the PARAM card, may be used to switch between viscous and structural damping. Viscous is the default and is used when PARAM, KDAMP is not present.
    KDAMP
    Results
    1 (Default)
    B matrix
    -1
    (1+ig)K(1+ig)K matrix
  8. If TYPE is G or blank, the damping values gigi are in units of equivalent viscous damping as:
    bi=giωikibi=giωiki
    If TYPE is CRIT, the damping values gigi are in units of fraction of critical damping C/C0C/C0 .
    If TYPE is Q, the damping values gigi are in the units of amplification or quality factor, Q. These constants are related by the following equations:
    CC0=g2CC0=g2
    Q={1(2CC0)1g
  9. To achieve identical displacements in Modal frequency response or Modal transient analyses when the SDAMPING is used instead of PARAM, G, the steps described here can be followed:
    • The TYPE field in the TABDMP1 or TABDMP2 Bulk Data Entry should be set to CRIT. This TABDMP1 Bulk Data Entry is referenced by the SDAMPING Subcase Information Entry.
    • Set the damping value (field gi ) in the TABDMP1 or TABDMP2 Bulk Data Entry equal to half of the value of PARAM, G (set to the constant value to C/C0 ).
    • Set PARAM, KDAMP,-1
  10. This card is represented as a load collector in HyperMesh.
