.h5 file
A binary file, containing model and result data.
File Creation
Supported Results
Refer to Results Output by OptiStruct for supported results in HDF5 format.
- Result support information for all
                        results available (in .h5 format) in Linear Static
                            analysis:Result Support Information FORCE / ELFORCE Supported element types: CBAR, CBEAM, ROD/CONROD, CFAST, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CSHEAR, CELAS1, CELAS2, CGAP, CBUSH, CWELD STRESS / ELSTRESS Supported element types: - CROD, CBAR, CBEAM, CONROD, CELAS1, CELAS2, CBUSH, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CSHEAR, CTETRA, CHEXA, CPENTA, CPYRA
- CQUAD4, CTRIA3, CQUAD8, CTRIA6, CHEXA, CPENTA, CTETRA and CPYRA are supported for CORNER and GAUSS results
 STRAIN JOINTF Supported for all element types. Reaction force, stop/lock status, viscous damping force, and elastic force of JOINTG elements are also output when JOINTF is requested. JOINTD Supported for all element types. SPCFORCE Supported for all element types. MPCFORCE Supported for all element types. GPFORCE Supported for all element types. OLOAD Supported for all element types. Temperature load of OSTTS is output by requesting OLOAD. ESE Supported for all element types. Group energy results are supported. RESULTANT Supported for all element types. Section forces and moments are output.
- Result support information for all results available (in
                            .h5 format) in Normal modes analysis:Result Support Information FORCE / ELFORCE Supported element types: CBAR, CBEAM, ROD/CONROD, CFAST, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CSHEAR, CELAS1, CELAS2, CGAP, CBUSH, CWELD STRESS / ELSTRESS Supported element types: - CROD, CBAR, CBEAM, CONROD, CELAS1, CELAS2, CBUSH, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CSHEAR, CTETRA, CHEXA, CPENTA, CPYRA
- CQUAD4,
                                                  CTRIA3,
                                                  CQUAD8,
                                                  CTRIA6,
                                                  CHEXA,
                                                  CPENTA,
                                                  CTETRA and
                                                  CORNER results. Note: There is only space for CORNER OR GAUSS results in the .h5 file. If both CORNER and GAUSS results are requested, an error message is reported.
 STRAIN EKE Supported for all element types. Group energy results are supported. ESE SPCFORCE Supported for all element types. MPCFORCE Supported for all element types. GPFORCE Supported for all element types. CSTRESS Supported element types: CQUAD4, CQUAD8, CTRIA3, CTRIA6 CSTRAIN
                        results available (in .h5 format) in Nonlinear Static
                            analysis:Result Support Information STRESS Supported element types: - CROD/CONROD, CELAS1, CBAR, CBEAM, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CHEXA, CPENTA, CTETRA
- GAUSS and
                                                  CORNER results are supported
                                                  for CTRIA3,
                                                  CTRIA6,
                                                  CQUAD4,
                                                  CQUAD8,
                                                  CHEXA,
                                                  CPENTA,
                                                  CTETRA. Note: There is only space for CORNER OR GAUSS results in the .h5 file. If both CORNER and GAUSS results are requested, an error is reported.
 STRAIN JOINTD Supported for all element types. JOINTF Supported for all element types. Reaction force, stop/lock status, viscous damping force, and elastic force are also output when JOINTF is requested. DISPLACEMENT Supported for all element types. SPCFORCE Supported for all element types. MPCFORCE Supported for all element types. OLOAD Supported for all element types. GPFORCE Supported for all element types. - By default, all results are output on-the-fly.
- In case of Linear Buckling analysis, only DISPLACEMENT result is available in .h5 format.
                            .h5 format) in Complex Eigenvalue analysis:Result Elements Supported DISPLACEMENT Supported for all element types. ESE Supported for all element types. Group energy results are supported. EKE EDE ERP Supported for all element types. - Complex eigenvalues are output in the COMP_EIGEN dataset for all complex eigenvalue loadcases.
                        results available (in .h5 format) in Frequency Response
                            analysis:Result Support Information ELFORCE Supported element types: CBAR, CBEAM, ROD/CONROD, CFAST, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CSHEAR, CELAS1, CELAS2, CGAP, CBUSH, CTETRA, CHEXA, CPENTA, CPYRA, CWELD STRESS Supported element types: - CBAR, CBEAM, ROD/CONROD, CFAST, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CSHEAR, CELAS1, CELAS2, CGAP, CBUSH, CWELD
- CORNER results are supported for CTRIA3, CTRIA6, CQUAD4, CQUAD8, CTETRA, CHEXA, CPENTA, CPYRA
 STRAIN DISPLACEMENT Supported for all element types. SDISPLACEMENT Supported for all element types. EDE Supported for all element types. Group energy results are supported. EKE VELOCITY Supported for all element types. SVELOCITY Supported for all element types. ACCELERATION Supported for all element types. SACCELERATION Supported for all element types. SPCFORCE Supported for all element types. MPCFORCE Supported for all element types. GPFORCE Supported for all element types. ERP Supported for all element types. RESULTANT Supported for all element types. Section forces and moments are output. JOINTD Supported for all element types. JOINTF Supported for all element types. Note: This form also applies to Result support information for all results available (in .h5 format) in Coupled Frequency Response Analysis of Fluid-structural Models (Acoustic Analysis).
                            .h5 format) in Transient Analysis:Result Support Information DISPLACEMENT Supported for all element types. SDISPLACEMENT Supported for all element types. VELOCITY Supported for all element types. SVELOCITY Supported for all element types. ACCELERATION Supported for all element types. SACCELERATION Supported for all element types. STRESS / ELSTRESS Supported element types: - CBAR, CBEAM, ROD/CONROD, CFAST, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CSHEAR, CELAS1, CELAS2, CGAP, CBUSH, CWELD
 STRAIN SPCFORCE Supported for all element types. GPFORCE Supported for all element types. FORCE / ELFORCE Support elements types: CBAR, CBEAM, ROD/CONROD, CFAST, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CSHEAR, CELAS1, CELAS2, CGAP, CBUSH, CTETRA, CHEXA, CPENTA, CPYRA MPCFORCE Supported for all element types. ERP Supported for all element types. JOINTD Supported for all element types. JOINTF Supported for all element types. RESULTANT Supported for all element types. Section force and moment are output.
                            .h5 format) in Random Response analysis: Result Support Information DISPLACEMENT Supported for all element types. VELOCITY Supported for all element types. ACCELERATION Supported for all element types. FORCE / ELFORCE Support elements types: CBAR, CBEAM, CBUSH STRESS / ELSTRESS Supported element types: CBAR, CBEAM, CQUAD4, CTRIA3, CQUAD8, CTRIA6, CHEXA, CPENTA, CTETRA, CSHEAR2. CQUAD4, CTRIA3, CQUAD8, CTRIA6, CHEXA, CPENTA, CTETRA are supported for CORNER results. STRAIN SPCFORCE Supported for all element types. GPFORCE Supported for all element types. CSTRESS Supported element types: CQUAD4, CTRIA3, CQUAD8, CTRIA6 CSTRAIN JOINTD Supported for all element types. JOINTF Supported for all element types. RESULTANT Supported for all element types. Section force and moment are output.
- Coordinate system information is available in the .h5 file for all the coordinate system types, except CORD3R and CORD4R.
