JOINTF
I/O Options EntryOutput request. The JOINTF command can be used in the I/O Options section to request output of JOINTG Forces.
JOINTF (format) = option
Argument | Options | Description |
format | <H3D, OPTI> Default = H3D |
option | <YES, ALL,
NO> Default = ALL |
- JOINTF output is only available in the .h3d, _impl.h3d, _expl.h3d, and .joint file. It is currently supported for all solutions for which JOINTG elements are supported.
- JOINTF output
consists of the following results:
- JOINTG Forces
- JOINTG Reaction Forces
- JOINTG Viscous Forces (available if PROPERTY on PJOINTG is DAMP)
- JOINTG Stop and Lock Status
- JOINTG Plasticity 1D (s) (available only in the .h3d file)
- JOINTG Plasticity 1D (s) includes 4 sub-results in HyperView: equivalent plastic displacement, potential function, damage index, and mode mix ψ. This result is only available for explicit analysis and supported for CARTROTA and CARDAN elements.
- JOINTF is set to YES by default for linear static and nonlinear static analyses.
- JOINTF outputs are printed in their own separate labels in the H3D file, such as JOINTG Forces (1D) (s), JOINTG Reaction Forces (s), and so on.
