EDE
I/O Options and Subcase Information Entry Used to request element energy loss per cycle and element energy loss per cycle density output for all subcases or individual subcases, respectively.
EDE (format_list, type, dmig, group, SUBSYS=SUBSYS_ID) = option
| Argument | Options | Description |
| format | <HM, H3D, PUNCH, OP2, PLOT, blank> |
| type | <AVERAGE, AMPLITUDE, PEAK> |
| dmig | <DMIG, NODMIG> |
| group | <PROP,
                                    COMP, SET,
                                    OPROP, OCOMP,
                                    OSET, INCL,
                                    OINCL> Default = blank  |
| SUBSYS | <SUBSYS_ID>  No default  |
                            ID of the subsystem. When used along a subsystem definition, this option generates an individual result file for each subsystem with results for that subsystem only. For more information, refer to the SET Bulk Data Entry. |
| option | <YES, ALL,
                        NO, NONE,
                    SID> Default = ALL  |
- When an EDE command is not present, element damping energy and damping energy density is not output.
 - Initial thermal strain is included in the calculation of element energy loss per cycle and element energy loss per cycle density.
 - Multiple formats are allowed on the same entry; these should be comma separated. If a format is not specified, this output control applies to all formats defined by the OUTPUT command, for which the result is available.
 - Multiple instances of this card are allowed. If instances are conflicting, the last instance dominates.
 - For optimization, the frequency of output to a given format is controlled by the I/O option OUTPUT.
 - type only applies to Frequency Response Analysis.
 - The three ways to calculate the Element Damping Energy in
                Frequency Response Analysis are:
- Output Type
 - Formula
 - Average
 - Amplitude
 - Peak
Where,- Corresponding Elemental Energy
 - Real Part of Displacement
 - Imaginary Part of Displacement
 - Elemental Damping Matrix
 - format=OUTPUT2 can also be used to request results to be output in the Nastran output2 format (.op2 file).
 - The group argument is only supported only for
                    Eigenvalue, Frequency response, and aeroelastic divergence analysis with H3D and
                    PUNCH formats. Group Damping Energy and Group Damping Energy Density are
                    available under the Element Damping Energy results type in the H3D file. In the
                    Punch file, the Property/Component ID’s and the corresponding Damping Energy and
                    Damping Energy Density are available.
If SET/OSET is requested a SID of Boolean set with operator OR is expected in the field option. Element SETs referenced when using this option should have the OPERATOR field set to OR. Regular element sets without Boolean OR are not allowed. SET/OSET is currently only supported for H3D and PUNCH formats.
 - Element Damping Energy is grouped and output for each INCLUDE file in the model. This is supported for linear static analysis, normal modes analysis, complex eigenvalue analysis, and frequency response analysis. It is supported for both H3D and PUNCH outputs. The corresponding elements in each include file in the model are automatically collected as element SETs of SUBTYPE=PROP where applicable and SUBTYPE=ELEM otherwise. These internally created element SETs are saved in the <filename>_sets.fem file which can be used for review. The SETs are named based on the name of the include file.
