GAPPRM
Bulk Data Entry Defines parameters that control connectivity and configuration checks for gap elements (CGAP and CGAPG). Most of these parameters also affect contact elements that are automatically created on CONTACT interfaces - see individual descriptions for details.
GAPPRM | PARAM1 | VAL1 | PARAM2 | VAL2 | PARAM3 | VAL3 | PARAM4 | VAL4 | |
PARAM5 | VAL5 | etc. |
GAPPRM | CKGPDIR | -1 | PRTSW | 1 | CHKRUN | 1 |
PARAM# | Name of parameter. | |
VAL# | Value of parameter. |
While textual values are recommended for clarity, their integer equivalents will also
be read. The available parameters and their values are listed below (click the
parameter name for parameter descriptions).
- Parameter
- Value
- The GAPPRM entry changes the default settings of control parameters for the gap elements connectivity and checks for configuration errors. None of the parameters of this entry are required.
- The gap alignment check controlled by the default value of CKGPDIR = ERR applies correctly to the most typical situations wherein there is an initial opening between bodies A and B, and the gap element is used to enforce non-penetration condition. For cases of overlapping meshes (combined with a prescribed coordinate system), the REV value is appropriate - it allows both aligned and reversed gap directions (respective to the gap axis defined by the prescribed system).
- This card is represented as a control card in HyperMesh.
