Bulk Data Entry For CGAPG and contact elements,
        controls how the projection onto the obstacle element (or node patch) is
        performed.
                            | Parameter |
                            Values |
                            Description |
                            | GAPGPRJ |
                            <NORM,
                                    1, SHORT, or
                                    2> Default =
                                SHORT  |
                                        - NORM or 1
                                        - The projection of node GA (or secondary
                                            node for CONTACT) to the obstacle B is
                                            performed along the normal to the surface of the
                                            obstacle (a patch of nodes or an element face). If such
                                            normal projection falls outside the patch of nodes or
                                            element face (within 5% tolerance), an error message is
                                            issued for GAPG elements, while no
                                            contact element is created on the
                                                CONTACT interface.
                                        - SHORT or 2
                                        - The node GA (or secondary node for
                                                CONTACT) is projected onto the
                                            obstacle B along the shortest distance. For cases where
                                            the normal projection falls within the bounds of the
                                            obstacle, this coincides with the NORM
                                            option. For cases where the normal projection falls
                                            outside the obstacle, this option will choose the point
                                            on the obstacle that is nearest to GA
                                            or secondary node.
