GAPPRM, HMGAPST
Bulk Data Entry Create HyperMesh command file that defines sets containing open and closed gaps for the initial set up and for each nonlinear subcase. The file name is <my_job>.hm.gapstat.cmf.
| Parameter | Values | Description |
| HMGAPST | <YES,
                                    1, NO,
                                    0> Default = NO  |
