AUTOSPC
I/O Options and Subcase Information Entry The AUTOSPC command can be used to automatically constrain stiffness singularities and near singularities with single point constraints.
AUTOSPC (output_print, output_punch) = option
AUTOSPC (PRINT, PUNCH) = YES
AUTOSPC (NOPRINT, NOPUNCH) = YES
AUTOSPC = YES
| Argument | Options | Description |
| output_print | <PRINT, NOPRINT> |
| output_punch | <PUNCH, NOPUNCH> |
| option | <YES, NO> |
- This entry replaces parameters PARAM, AUTOSPC and PARAM, PRGPST.
 - The SPCOFF and SPCOFF1 Bulk Data Entries can be used to exclude degrees-of-freedom from AUTOSPC.
