SPCOFF1
Bulk Data Entry Defines degrees-of-freedom to be excluded from AUTOSPC.
SPCOFF1 | C | G1 | G2 | G3 | G4 | G5 | G6 | G7 | |
G8 | G9 | etc. |
Alternate Format
SPCOFF1 | C | G1 | THRU | G2 |
SPCOFF1 | 3 | 22 | 12 | 52 | 7 |
Alternate Example
SPCOFF1 | 4 | 9 | THRU | 52 |
Definition
C | Component numbers. (Integer zero or blank for scalar points, or up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks for grid points). |
Gi | Grid or scalar point identification numbers. (Integer > 0 or “THRU”) |
- Degrees-of-freedom on this entry will be excluded from AUTOSPC.
- If both SPC and SPCOFF1 are defined for the same degree-of-freedom, then SPC takes priority.
- For the THRU option, all grid points numerically in between G1 and G2 are not required to exist.
