Nonlinear Transient Heat Transfer Analysis
Calculates the temperature distribution in a system with respect to time.
The applied thermal loads can either be time-dependent or time-invariant; transient thermal analysis is used to capture the thermal behavior of a system over a specific period of time.
The basic finite element equation for nonlinear transient heat transfer analysis is given by:
Where,
        - Heat capacity matrix.
 - Temperature-dependent conductivity.
 - Temperature-dependent boundary convection matrix, due to free convection.
 - Derivative of the nodal temperature matrix with respect to time.
 - The unknown nodal temperature matrix.
 - Radiation exchange matrix.
 - Absolute temperature scale defined via PARAM, TABS.
 - Thermal loading vector.
Thermal load vector can be expressed as:
    - Power, due to heat flux at boundary specified by QBDY1.
 - Boundary convection vector, due to convection specified by CONV (automatic free convection definition can be activated via CONVG Bulk/Subcase pair).
 - Power vector, due to internal heat generation specified by QVOL.
 - Boundary radiation vector, due to radiation specified by RADBC.
Note:
- For Nonlinear Heat Transfer Analysis, Conductivity ( ), and/or Free Convection Coefficient ( ) are temperature-dependent.
 - The differential equation is solved by backward Euler method to find nodal temperature at the specified time steps. The difference between this equation and the Linear Steady-State Heat Transfer Analysis equation is the term, , that captures the transient nature of the analysis.
